Showing results for tags 'spaghetti-bolognese'.
Version 2020.09.29
78 downloads
LCD Case Mod I have made some changes/improvements to the Mini12864 LCD case as follows: I found the hot melt inserts to be difficult to align straight, on both the rear and front case due to the geometry and space constraints. I have therefore removed them and resized the holes accordingly. For the case rear, I have added M3 threads to the 4 fixing holes, these should print fine with standard Voron printing settings. I have added a lip around the screen cutout to better hide the PCB board behind it. This is simply for aesthetic reasons. I have added an E-stop button cover, taking inspiration from both the previous Voron LCD cover as well as the Prusa i3 design. This allows for both easier prodding of the E-stop button as well as improving the aesthetic of the case (in my opinion). Standard vs. modded design comparison Please see below the changes between the standard/stock LCD case in the first image, and my modded design in the second. Installed Case Mod Installed and working well -
Version 2020.09.29
65 downloads
Simplified Z Drive Motor Mount Issues with original design I have had issues with alignment on the 188mm Z drive belts causing the belt to rub on the motor pulley. I found that the motor mount was difficult to align squarely with the frame and this was causing the pulley misalignment. I haven't noticed any print issues caused by this misalignment but it will prematurely wear the belts, not to mention that the rubbing noise is not something I'm happy to live with on a £1200 printer. I found the problem was caused by the design of the tensioner which means there isn't much space for the alignment key feature used to align the motor mount into the aluminium extrusion of the frame (shown highlighted in blue). Simplified design I have simplified the design by combining the tensioner into the motor mount. Belt tensioning works by a small protrusion which pushes against the side of the Z drive housing (inspired by the original design). I have tried to keep the belt tension the same as is acheived in the original design. Assembly is surprisingly straightforward and cuts out a few of the steps required with a separate tensioning arm. Combining the tensioner into the motor mount has created space for the extrusion slot key to be extended across the entire face of the motor mount, allowing for the key to work more effectively in aligning the motor mount squarely to the frame and ensuring that the motor pulley is aligned with the belt and 80T driven pulley. The only downside I see is to the 'cool factor' The original design looked pretty awesome with the contrast of the tensioner handle, now it is a bit boring looking if I'm honest but it is very functional. I'll leave it up to you to decide whether its worth the change.
