Showing results for tags 'maximilian-foerg'.
  • Other FDM Printers
    • Anet A8 / AM8
Found 2 results
  1. Version 2022.04.03
    41 downloads
    Double 60mm Fan Mount for Voron Switchwire This is a simple mount for two 60mm fans in Switchwire's electronics compartment. It uses screws instead of VHB tape and was inspired by this mod. Of course you can also print it twice and mount four fans. Note that using fans in this position only makes sense if you use the deck and bottom panels, as they form an air tunnel. Without them, the fans will only blow against the frame and the air will not reach the electronics. BOM Item Qty. Note BHCS M5x10 2 M3 Heat Set Insert 4 SHCS M3x25 4 Screw length depends on the fans used Images
  2. Version 2022.04.03
    122 downloads
    Voron Afterburner Turbo Mod This is a purely cosmetic mod for the Afterburner to bring it's appearance closer to Stealthburner. After having seen Stealthburner, Afterburner's design started to look a little dated to me. So I designed this mod. It simply replaces both of Afterburner's front parts with a single part. The only new hardware required are two shorter screws. BOM Item Qty. Note SHCS M3x20 2 Replace two SHCS M3x30 Images
