Showing results for tags 'bed mesh'.
  • Other FDM Printers
    • Anet A8 / AM8
Found 2 results
  1. Hello there, just finished building my 2.4 kit (LDO) and did some prints. I noticed, my bed wasn't flat, did a mesh. (see picture) the result made me check my gantry, I did check squareness that again, to be sure. Checked my extrusions, since I crashed into the bed, while configuring klicky, seems all fine, nothing bent. I loosened all connections, while doing that, including the x/y rails to be sure there's no misalignment or slight bent from heat. My bed is heating at 70% max, well within recommend power. I can't get my head around the bed "warp" in the corners. Any suggestions anyone? To me, it seems the magnetic sheet is not flat. The corners are 0.25mm high, the middle is dead flat within 0.02 Sorry for the bad Pic, I have nothing else atm,since I'm away from home.
  2. Can someone help me understand these results? The BED_MESH_CALIBRATE command appeared to run properly but when I look at the Heightmap, shouldn't the Max and Min be closer to 0? Thank you, Bob
