Showing results for tags 'abs+'.
  • Other FDM Printers
    • Anet A8 / AM8
Found 2 results
  1. Hello, yesterday I got some ABS+ from eSUN shipped to be used in some machine building application. After setting up the printer profile accordingly to the eSUN documentation (eSUN-Fast-filaments-print-parameters.pdf (esun3d.com)) I started a test print to validate the material. (Simple 15mm x 15mm tower) I noticed that in contrast to the normal ABS I have laying around (and also PLA) the layer adhesion is pretty bad and I can crack the print with "not that much force" (I still had to use pliers) straight at the layer line. In contrast to the normal ABS where I was not able to split the print clean at the layer line and I also had to use way more force to rip anithing of the wall. Does anyone had the same problems with this filament and is there a fix to it? For the used printer profile: Except the values from manual I set the minimal layer time to 15 sec. I also checked, if I can print it with higher temps (up until I got temperature artifacts) but there was no improvement. The ABS and ABS+ towers are printed with the same temperature (red is ABS and violett is the ABS+ one).
  2. Found some here, but shipping to europe is ridiculous.. https://sparta3d.ca/collections/abs-filament/products/sparkle-abs-filament But I love the colors, no idea how it turns out printing though...
