Version 2022.07.24
579 downloads
V2.4 Handle
Carrying handle for Voron 2.4 with 6mm clearance for panel clamping. The design was heavily inspired by https://github.com/yanyixiang/Voron/tree/main/舒服坚固的手把BY_路易斯亚细亚.
The handle is mounted on 2020 aluminium extrusions with 5 T-nuts. It should also fit on Trident and Voron 1.8.
default Voron print settings
no supports needed
use accent color for middle part
Size
Qty
M3x12 SHCS
M5x16 BHCS
5
M5 T-Nut
5
M3 heat set inserts
Assembly instructions
put heat set inserts in inner handle part
put T-nuts in aluminium extrusion (2 T-nuts in top slot, 3 T-nuts in side slot, coarsely adjust hole distances)
attach inner handle part to top side of the extrusion
attach middle and outer handle part to the side of the extrusion; do not tighten M5 screws yet
align parts and put in M3 screws; tighten all screws
