- 0
Buurman
Hi,
I have two Vorons, slightly different but both Formbot kits, my first two Voron builds.
One Voron make a bit more noise than the other, and I am starting to investigate why.....
I switched out motors, since they were a slightly newer model on the second voron, but that didnt change the situation.
I feel that on the silent Voron, the hotend is moving easier and without difference in fraction.
On the "loud" Voron I feel differences in fraction, not mechanical, but like motor resistance, but not constant, like every 7cm it gets a little more resistance, that you need to push through, and then it start over again. This is not the rail, I removed the belts, and without belts its smooth as a baby butt
(I can say that as a daddy, I hope)
It does this with motor wires off, since its never good to move your axis (faster) with wires connected.
Anyone having a idea where this might come from? nothing is loose, nothing seems out of center...
Things I may check still:
Anything else.. dont know.. again, motors swapped already... belts double checked...
39 answers to this question
