Voron 2.4r2 350 mm getting serviced & updated aka "Rabbit Hole"
I have been running my 2 Voron 2.4, a 300 mm and a 350 mm, for a few years now with excellent results and minor updates/upgrades, like Klicky probe, Release 2 updates, part cooling 5015 fan, Nevermore filter and some cosmetic changes.
It is also time to replace some plastic parts, deep clean and grease the linear rails, check belts and pulleys etc.
The 300 mm Voron 2.4r2 (aka Voron-1) is running great for about five years now with the above upgrades and minor maintenance, so it was the first one to get an upgrade and maintenance.
Stealthburner with LGX Lite v2; originally full size LGX. Reuse the Mosquito hotend with new heater and thermistor, and Convert from conventional cables to CAN network and finally go from Klicky probe to CNC Tap system.
After rails serviced, new plastics printed and all the new parts for the Stealthburner, including LEDs, EBB etc. put together, the Voron-1 is back in service and working great!
The CNC Tap system works great and love the simplicity of the CAN network; four cables! The cable chains look empty now!
So it is time to service and update/upgrade the 350 mm Voron (aka Voron-2). But, I am not too happy with the part cooling performance of the Stealthburner, especialy try to print PLA fast, so I started researching other solutions. Of course, CPAP turbine and hose is the top contender for supplying part cooling air. Then I found the wonderful Github site of sneakytreesnake and his not Voron mainstream head CrownCooler. Unfortunately, is designed for Orbiter with a Rapido head. I have a Mosquito and a LGX Lite V2; so here we go to Fusion360!
The existing projects I will be using are:
9 hours ago, TitusADuxass said:
From my experience, that muffler doesn't bring much to the party.
I'm having a serious look at this one https://www.printables.com/model/935635-mammoth-3d-cpap-muffler-version-135-voron-24-voron
Many, many thanks @TitusADuxass!
That's what I was looking for! Size matters when it comes to sound!
I have not tried the VZbot intake muffler yet, but I thought it was too small of a sound chamber to do any significant reduction. Anyway, I needed something to start, and many other solutions are using external air which will be great for PLA but not good for ABS, ASA etc. Eventually, I need to find/make a solution that uses a baffle that automatically draws the correct air for the filament used.
The only other "muffler" I have found CPAP Muffler System - C.M.S that it had potential but I needed something quick because I am working on the completely new head and needed a quick print tot test it. The designer of the CMS muffler had some good points and I will try eventually:
  • Enclose the turbine housing in a sound deadening material.
  • "Soft" mount the turbine as I am sure is not balanced at high RPMs....
Cheers!
Functional head completed and ready to test.
Some stats:
  • Extrusion nozzle to linear rail carriage 28 mm (Stealth 28.10 mm)
  • Overall width 84.966 mm (Stealth 85.216)
  • Height from nozzle to Extruder lever 105.357 mm (Stealth 145.063 mm).
  • 3 printed parts for everything; no cosmetic or LED/camera mounts yet!
Need to add the EBB36 CAN holding frame and wire everything before for 1st run.
Some images:
20250408_132729.thumb.jpg.92dec4b1168a8f6e8026aac440119b26.jpg20250408_132801.thumb.jpg.bdc10053bfaaa74a1c87c0f5158f22af.jpg20250408_131858.thumb.jpg.f42aea60898703693af3a27af3ce9698.jpg
It's amazing how "clean" it looks with the 2 wire chains gone!
Hopefully, it actually works too! 😅
Cheers!
Edited by NikosSprocket
3 hours ago, NikosSprocket said:
How?
There are still 2 motors (X & Y) and the Y stop switch wires to contained.
Mod it to a horizontal chain mod - takes 10 minutes (not including printing the parts). Will also free up space in Y and prevent the toolboard from hitting the cable chain:
My Voron 350        My   Voron 300
image.thumb.png.a2c44cb4a37edbfd87d6a9e3b84475b5.png  image.thumb.png.92d5d2c3cb2f231bf4c1a967997f0747.png
Or you can do a horizontal Z umbilical - for me that was too much effort for little gain. (Have to re-wire and crimp the two motor leads)
This is from hartk:
27 minutes ago, NikosSprocket said:
Let's see how it will do under speed. 😱
I'm actually curious how fast your Voron can get.
What are you going to shoot for?
Currently I'm printing ~200mm/s @ 5K acceleration.
17 hours ago, NikosSprocket said:
How?
I'm running sensorless, so no Y stop switch.
I've got 4 motor wires in an umbilical from the centre of the gantry down to the hole in the baseplate.
The 300 mm with the updated Stealthburner is running ~200 mm/s @6K. My current problem is cooling and can be seen clearly on prints with overhangs that start looking bad after a few perimeters only on the back side of the printed object. Placing the object 90 degrees from the previous location will print that overhangs with better results. For example, for the Maker's Muse Torture Egg, I need to slow down the print job down to 45% speed to get good overhangs at the very bottom and top sections. The rest prints great at full speed.
Yup, that sounds about right for the Voron. I'll try squeezing another K or two out over the weekened. Thanks.
That's been my experience as well. I experimented with the wall printing order in Orca Slicer. While not perfect I did get better prints overall using Inner/Outer/Inner over the default Inner/Outer. In the past, I never paid too much attention to overhangs because they were generally OK-ish or good enough and got the job done. Now I want a bit more surface quality. So, Rabbit Hole it is... I'll give the Torture Egg a try and see if I can get some improvement.
