- 0
mbunjes
I hope the learned participants of this forum can help me with a baffling (for me) problem.
I can’t get a reasonable Z-Offset dialled in. I do the probe-offset with the paper, everything looks fine, I start a test print and this is the result : (The right side is were the print starts) : that is way too low to my thinking.
I did some babystepping and ended up with the left side, which looks reasonable.
After accept and save_config I then started a print for real and the print wouldn’t stick to the bed at all, the z-offset is obviously way too high. I’m confused now,
maybe the EM needs adjusting ? But how to do that if I can’t even get a decent first layer ?
The printer is a Trident 350 with TAP and a brand new build plate from oseq which comes highly recommended.
The filament is Esun ABS+ black which I always use for everything.
19 answers to this question
