- 0
AdSiJu
Somewhere along the line I must have flashed the wrong firmware to my BTT Octopus 1.1 or did something to kill it. I can't get it into DFU mode. I can't see it plugged in usb. It doesn't show anything when I type "ls /dev/serial/by-id" or by-path. nothing shows up when I run "ls usb". I have tried flashing from SD card, but it never takes the file off the card and changes the extension, the blue light comes on indicating an SD card is inserted, but it never flashes for activity. I have hit the reset button, double tapped the reset button, held the reset button while powering up, all to no avail.
I had tried to flash the Octopus with firmware to run directly from the Canbus on board, but I couldn't get it running, so I switched to a U2C adapter plugged into the Pi. ever since then, I can't connect to the board.
I have looked to see if I had the raspbian glitch that kills USB connectivity, but I am up to date on raspbian, klipper, mainsail, and everything else on the pi.
any other ideas or am I just going to have to bite the bullet and buy another board?
6 answers to this question
