- 0
Yarkinco
Hello guys, I really need some help. Today I spent almost 8 hours to understand this position_min, position_max, position_endstop and all other things like bed levelling.
I am lost. I am clearly lost. I need someone to explain it to me like explaining it to a complete IDIOT. I am building a Voron 1.8 (Yes I know a trident is much better, v1.8 has some problems etc. but I had a kit bought long ago. It is just me to start build it in last 2 months in my free time. I did not want to spend extra cuz I already had everything I needed for 1.8)
This is my current layout for bed and z steppers. my z endstop is a mechanical switch. I also have a magnetic probe for z installed on the toolhead.
and below my code, which I think related to all this stuff.
[stepper_z] step_pin: PE13 dir_pin: PC2 enable_pin: !PC0 microsteps: 16 rotation_distance: 8 #endstop_pin: probe:z_virtual_endstop endstop_pin: PG8 position_endstop: -2 position_min: -2 position_max: 250 homing_speed: 5 second_homing_speed: 3 [stepper_z1] step_pin: PE14 dir_pin: PA0 enable_pin: !PC3 microsteps: 16 rotation_distance: 8 [probe] pin: !EBBCan: PB8 #control_pin: EBBCan:PB9 x_offset: 0 y_offset: 23 z_offset: 0 speed: 10.0 samples: 3 samples_result: median sample_retract_dist: 3.0 samples_tolerance: 0.006 samples_tolerance_retries: 3 #[z_tilt] #z_positions: # -35,180 # 290,180 #points: # 30,155 # 220,155 #speed: 200 #horizontal_move_z: 10 #retries: 5 #retry_tolerance: 0.0075 #[screws_tilt_adjust] #screw1: 40,180 #screw1_name: Bed Fix Point 1 #screw2: 210,180 #screw2_name: Bed Fix Point 2 #screw3: 125,10 #screw3_name: Adjustment Screw #horizontal_move_z:5 #speed:200 #screw_thread: CW-M3
As you can see, z tilt and screw adjust are commented. I have 0 clue how to set them. Does anyone has a nice guide which explains it like the reader is complete idiot like me?
Edited by YarkincoLink to comment
0 answers to this question
