Dynaco ST-120 Tube Amplifier
Penatr8tor
I know this is way way off topic but there are a good number of parallels with building a 3D printer, at least from an electronics perspective.
This kit is available at Tubes4HiFi and can cost from $1200 US to $2K depending on what extras you add on. I got mine with basic tubes and I added Pentode-Triode switches and 2 matched pairs of NOS Russian paper in oil coupling caps.
And lastly, we test and set the bias for the output tubes.
All done... Sounds awesome!
On top is a Bottlehead tube preamp. It's been retired for a while now, but it was also a fun build.
Figured I'd throw a couple photos of the Bottlehead Foreplay III preamp as well.
47 minutes ago, claudermilk said:
BTW, gorgeous table that it's on in the first photo. Seems a shame to cover it with the electronics.
You're right about that. I need to get myself a replacement and put that table back in service. That table is from Syria and hand inlayed. It's a gaming table. The top rotates 90 degrees and you open it up.
Inside is an insert that has a chess board on one side and a felt mat for cards on the other.
If you take out the insert completely... There's a backgammon board.
And underneath the table is storage for all your gaming supplies.
Goes great with my Elephant (carved from soapstone)
Edited by Penatr8tor
Forgot something...
