Eddie Current Probe Comparison - a PERSONAL viewpoint
5 minutes ago, sleepster217 said:
I am not sure if u have or not but I have the stick on bamboo labs silicone nozzle brushes on mine and can link the stl I used if u want it but u may have all rdy changed over
I have already converted all printers to the Bambulabs silicone wipers, thanks
All good did not like the fact that the bronze ones bend and don't work well after a little while and silicone just stays good well that was my theory
1 hour ago, PFarm said:
Has anyone used the Beacon reasonance test? Documentation is a little vague on how to use it.
That's probably because there's not much to it.
Just plug this into your printer.cfg
[resonance_tester]
accel_chip: beacon
probe_points: 150, 150, 20
Probe points is the toolhead position for testing.
Then just run
TEST_RESONANCES AXIS=X
and
TEST_RESONANCES AXIS=Y
and the rest of the SSHing and making graphs etc.
Here's the link to klipper so you don't have to hunt around.
