Cheap 3D printed pellet extruder
xyleth
The more major quote for the video and this extruder is the simplicity and that he tells that it is not as perfect as a common 3d printer.
After realizing that if you go away from "must look perfect" this is a dam cheap way to print at low cost.
Even the color choice can be easy if you use master batches.
The only complicated thing is a recipe and a way to order the pellets. Most batches are sold in 20 or 50 kg and the master batch goes for about 1 to 5 kg.
But if you print loads of the same material it's a money saver.
It's just not that perfect
I'm following him just to se how it ends up.
