Milo V1.5 CNC Bench Mill - Water Cooled
PFarm
1 hour ago, oggie said:
Ok great I am waiting on some more parts before I start building waiting for send cut send for my z plates as well as my motion kit I ordered from Ali
Ok cool! Have you purchased the X/Y and Z plates? I see that West 3D has them in stock.
Plates
Completed the final termination of the external wiring only the touch probe to wire to the 3-pin Deutsch when it arrives. Temporary installation of the tool setter, I'll need to re-mount when I get the X fixture installed.
Z stepper motor wiring completed and secured
Routed and secured the thermistor for the rad temperature monitoring.
Replaced the front feet support with the tilt mod feet support since they bolt to the table with four screws instead of just two (front and side screws). IMG_2391.thumb.JPG.2702be69afea047d08ce8ecb856026b8.JPG
I received the water-cool fittings I was missing to connect the tubing to the water-cool components.
This M8-1mm pitch male x 10mm hose bard. The tube fitting shipped with the spindle didn't fit the 10mm ID tubing that I had.
The vent fitting for the water reservoir that relieves the internal pressure when the water warms up.
The G1/4 coupler so I could connect the water flow/temperature gauge to the reservoir.
Using my variable power supply, I connected the 12v for the gauge and pump. I got the water system filled.
