Milo V1.5 CNC Bench Mill - Water Cooled - Casa Enclosure
PFarm
Clicky Clack style doors and hinges are installed, they give the compartments easy access. By the way, the door can be lifted off. I'll drill and tap the main frame to secure the doors with 2 x M3 screws on each door. IMO, it was worth the extra 2020 extrusion!  👍
  • PFarm changed the title to Milo V1.5 CNC Bench Mill - Water Cooled - Casa Enclosure
Secured the din rail directly to the 2020 and added a center support piece.
Printed these "O" ring feet, drilled and tapped the corner feet support for an M5 screw and used a nylock nut to lock it all in.
I modified the step file to accept the bulkhead Deutsch connector 2 x 8pin, 1 x 12pin and another for the power inlet.
Got some components mounted in the E cabinet, 36V, 24V, 12V power supplies, LDO expansion module, Mellow motherboard and Mellow 5160 Pro with fans, water cool radiator at the back of the E compartment and the water reservoir and pump.
I got the filler panel modelled and added a momentary switch for the air blast of the tool setter. Rocket switches are on their way. 220V wired to E-stop and the power supplies. Stepper motor wires bundled and ready to terminate. I moved the radiator to a new location and mounted the water pump.
I have been tinkering with Fusion 360 and was able to model these bulkhead panels from a step file, trial & error and YouTube video I accomplished what I wanted. It's nothing complicated but an achievement for me! Thanks again to Penatr8tor for the Zoom session that got me started using Fusion 360.
From the motherboard to the bulkheads harnesses for the end-stops, probes and ring led on the spindle.
Bulkheads installed and wired. 2 x 8pins, 1 x 12pins and 1 x 4pins yet to be installed for the spindle 220V.
5V power supply arrives Monday for the E-compartment and Milo compartment RGBW Neopixels. The 400 M3 spring T-nuts arrived but still waiting on the M3 screws to install panels and skirt.
I moved the water pump to its final location
I used the second relay on the LDO expansion module to trigger the water pump and radiator fans when the spindle is activated. M3 x 10 arrived today so I can start closing up panels and installing the skirts.
I installed the 220V VFD/spindle power bulkhead and printed a filler piece. Two 24V solenoids arrived: one for the tool setter air blast control by a momentary switch and the other for constant regulated air supply at the spindle cutter.
Slow progress I've been fighting this cold for the last week or so.
You are most welcome Jack.
Once you get over the learning curve... A whole new world opens up. 🙂👍
