My first build / 3d printer
sleepster217
So I learnt from a mistake and if any one else has one tell me if I went wrong so I got a belt tension gauge yes from ally express 😅 and on it instructions it says pull thing out (tyre tread depth gauge zero and place belt on pins and release 9mm belts should be 7.9mm on gauge and 6 mm is 8.9mm so I did that moving gantry after each adjustment to make sure the reading was true and do the mesurment a couple of times well I ended up snapping a 9mm belt
On a better note the beefy rollers are strong lol
At least I got extra belts in case I had some sort of trouble any way this is how we learn hey
1 hour ago, sleepster217 said:
...well I ended up snapping a 9mm belt
That's a first.
After building 5 printers and a couple rebuilds I can say with confidence... You can easily get lost in the minutia. As far as belt tension goes... I tried most of the tensioning tricks or techniques like plucking the belt like a guitar string and matching the pitch to you name it. This printable tension gauge worked the best out of the things I've tried. Also, you will get a better perspective on belt tension once you see them in motion. You want the least amount tension as possible without slipping and slapping. Slipping is obvious, slapping (I made that term up LOL) is when you see the belt vibrating when the print head changes direction.
TBH and back to the whole minutia thing... you'd really have to screw up the belt tension for your printer to not print decently due to belt tension. Same thing goes for things like the print bed. I remember people getting all bent out of shape because they probed their bed and it was off by 0.1mm. I built a little RatRig V-Minion 180x180x180 bed slinger, and the bed has zero adjustment and is tilted ~.25mm in the X and with a bed mesh... it makes beautiful prints and beautiful 1st layers.
So, in closing, it looks like you're really close to finishing your build and it looks really nice BTW. Get your belts tensioned by feel and get your printer printing. Then get into the little piddly stuff. You probably already said that to yourself, but I just have to put my Old Man 2 cents in. 😄
7 hours ago, Penatr8tor said:
That's a first.
Yeah thankyou for that I did notice the x y belts if one was tighter than the other the gantry will not hit the end square like it use to so I ended up going by that
22 minutes ago, sleepster217 said:
Hi I have a btt tmc 2209 v 1.3 and cannot find the config and any jumper info for these I can find the 1.2 are they the same or any information that I need to config my octupuss pro
There should not be any hardware configuration needed for these. They are stepper drivers and the configuration is done in the printer.cfg file under [tmc2209 stepperX/Y/Z/Extruder]. As example:
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
The uart_pin is the board pin. In your case the Octopus board. (In the below table designated as CS)
Just make sure your jumpers for the steppers are set to UART mode.
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
Thankyou
Looking good - the drivers are set for UART. As per the Voron manual, you need to remove the 5V USB power selector jumper (yellow) and the row of diagnostic jumpers (orange)
image.thumb.png.b3fdd1d0fbbb856bfe13993a40af7819.png  image.thumb.png.86eaa060f2f818ac8aba962c3956f6bc.png
Also remember to select Fan Voltage - yours are all on 24V which is standard and ok if the fans are all 24V. The part cooling fan and hotend fan will run off your canbus board so no need to worry about those.
All my fans are 24v
5 minutes ago, sleepster217 said:
I appreciate all the help and I hope I am not just being stupid with this as I don't feel like smoking up one of my boards
I assume it is this jumper than needs to be set right need the black can out and the one that says 120r as there is 3 120r in different locations
