My first build / 3d printer
sleepster217
On 5/28/2024 at 1:03 PM, Penatr8tor said:
Yes, you need the hat to run the NVME SSD. I specifically reference "NVME" because the old SATA M.2 drives will not work.
The hat will also work if you have the Pi5 official active cooler installed (which I do) and what's nice is that the fan on the 5 has a special connector and doesn't use the PIO power pins. You also get a PIO pin riser with the hat as well.
I have this one -> Waveshare NVME Hat $16 US
And I'm using this for my SSD -> Samsung 256gb NVME SSD $25 US
And the Pi5 cooler -> Active Cooler $13 US
I also went ahead and bought an NVME to USB Adapter $11 US to flash the Pi OS onto the drive from my PC.
All told the total additional isn't really that much (~$65 US) considering the benefits over the old Pi.
Can this same type of setup be done on an RPi 4??
I will expand on what @mvdveer said...
Yes, it will but you are giving up a good amount of performance by going with the Pi4, and not processor performance between the Pi4 and Pi5 which I believe is ~4-5X faster than the Pi4. The big difference when it comes to storage between the two is that the Pi4 has no PCI Express lanes built into it, so with the Pi4 you have to use USB 3.0 to connect. The speed difference between PCIe and USB is... PCIe 2.0 X 1 = 500 MB/s versus USB 3.0 = 0.626 MB/s (~300X faster) and I will toss this in for good measure... The Pi4 USB ports are shared so additional devices you connect are going to use some of your USB bandwidth.
So, to reiterate... Yes, it can, but would I? Probably not. Using an NVME SSD for storage was never part of the design of the Pi4 and using one thru USB is a compromise where you're losing a most of the performance advantages because you cannot use the intended interface. The Pi5 on the other hand has been designed to take full advantage of the NVME interface.
Final Advice: Get a Pi5 and call it a day or if you don't want to switch or can't afford it... then make sure you have a good name brand SD card to get the most performance and longevity out of your Pi4.
Edited by Penatr8tor
Misspelled some stuff
Thankyou for the extra information I will look at getting a Pi 5 instead now
Thought I would fit up the print bed will need to remove later as I have not ordered the heater and flex sheet yet but wanted to see what it looked like fitted I also fitted the nozzel brush but will be taking it to work to use some adhesion promoter so the brush sticky stuff dose not lift as quick I am also waiting on the magnets for the purge bucket the nozzle brush I used has the sheet stops as well just to be fancy
Edited by sleepster217
1 hour ago, sleepster217 said:
What glue dose everyone like to use to glue in the magnets so they don't fall out over time ?
Comes with adhesive on the magnetic sheet. Apply downward pressure with a roller or plastic spatula while pulling back the protective adhesive paper a bit at a time.
Sorry I mean the little round ones for the doors etc as I need them for the purge bucket
I use gorilla glue (Superglue) from Bunnings
