Voron Build Tools Mega-List - 2024 Edition
Demosth
A very handy tool indeed, very useful for those more delicate jobs such as reaming or drilling out the smaller size holes. I usually clean out my 3mm inserts with a tap after pressing them in with the soldering iron. You can also find them on places like Ali Express, Temu etc.
13 hours ago, Wannabe said:
Yet another useful tool.
https://www.amazon.com/Hobbypark-0-14mm-Puncher-Reamer-Drills/dp/B01EIH573K
Also available from Ali Express, Temu.
Yup, and if you go back one page, you'll find that I already posted this tool last October. 😄
I will say this about those tools though... I have two of them, one has about 2-3 degrees more taper than the other one. So, if you are in the market... The tool with a bit less taper works better i.e. removes more material per twist.
This is the more taper one - Doesn't work that well for 3D printed holes.
This is the less taper one - Better for 3D printed holes.
  • Demosth changed the title to Voron Build Tools Mega-List - 2024 Edition
Hi,
 I am new to building Vorons, but have worked my way through a couple of Deltas.
I would add a few Allen keys of the screw driver type.
Perhaps a torque limiting screwdriver and the torque gauge that Prusa suggest s to print and attach to a regular L  Allen wrench.
I just posted a thread about a "square" that I plan to use for my 2.4 kit (just ordered an hour ago,)
Not just a tool, but potentially a frame stiffener if I leave them in.
Here is the little "square" that I made.
NOTES:
1) it ain't perfect, but I think it will be usefulcorner-brace-3.STL
2) I wanted to go as deep into the 2020 slot as practical - without my actual kit and no CAD drawings of the 2020's section I was only able to estimate the edge flange as 2 mm thick.
3) The only CAD drawings I have of Tee nuts for this are for 5mm slide in ones and they go 1.4 mm into the slot from the inside, so I made allowance for them to come in that full 1.4 mm.   For NOW I am printing those in ABS, the mid term plan is to use roll in nuts.
Tee Nut.SLDPRT
I retired my old multimeter, which I used at work for over 20 years. I thought I'd give this meter from Aliexpress a try, I have to say I'm impressed shipping was quick, at $32.00 CND it was worth the gamble. Multimeter
Nice features and the large digital display is great, eyes aren't what they used to be. 🙂
  • Like 6
