9
The screen is held in via 4 m3x8 socket head cap screws, which go into the housing from the back and thread into the bezel. The bezel is secured over the accents with a couple drops of super glue.
The only two required supports are integral to the model and "print-in-place". They will need to be removed after the print is finished.
I tried to design this so that it would require minimal supports, but the honeycomb pattern has some fairly long bridges. Depending on your printer's overhang and bridging performance, you may need additional supports. Prusa Slicer's organic supports set to 30* worked very well for me on a similar design.
