6
Since the camera perspective at the front above offers a good overview but you cannot see what is happening at the nozzle, I looked for a solution for a second camera. Since the Voron is designed to be quite space-saving, it wasn't easy to find a free corner. I then found a camera circuit board with a USB connection on Amazon that can also be extended.
Here's a link to the camera, hope it's OK here: Link
Make sure that longer cables are shielded, otherwise you will have connection problems.
I used self-tapping screws to screw it on
