5
The Clearview Infinity mod for the Voron 2.4r2 and Trident is an upgraded enclosure system that offers both better performance with a commercial grade design aesthetic. The name "Clearview Infinity" correlates to the visual aesthetic of the transparent panels. 1/4" HD polycarbonate panels and oversized hardware are designed to take give this a commercial grade fit and finish. More so, the added function that this enclosure set adds is better heat retention for advanced printing, reduced noise while printing, and a strong sturdy enclosure that feels like a professional piece of lab equipment. All due respect to the Voron team for making an amazing printer, but we thought the enclosure portion needed some help.
Open Source mode:
We want to offer a way to open source this mod for those who DIY. At the same time, we build these enclosures to make a living and we put a lot of work into the design, function, and finish of the enclosures we make. That said, we will give you alternative open source parts that you can use to complete your own Clearview Infinity enclosure or it is available for purchase through our website. In the spirit of being a maker, we'll happy to share our idea and the work it takes to make a great product.
What is included (BOM)
- 5 Polycarbonate panels (5.5mm or 6mm) (Front, sides, rear, and top)
- 52 m5 x10mm flanged screws
- 52 m5 half round extrusion nuts
- 16 m4 x10mm flanged screws
- 12 m4 Rivet nuts
- 4 5mm x 10mmx 5mm magnets
- 1 - 256mm pull handle
- 1 press fit bowden holder
- 1/4" wide weather seal
Printed parts
- 3 - 270 degree hinges
- 2 - Magnetic brackets
- 1 - combination rubber grommet
- Panel 1 Front 421mm wide x 435.5mm tall
- Panel 2 + 3 Sides 410mm wide x 430mm tall
- Panel 4 Rear 421mm wide x 430mm tall
- Panel 5 Top 421mm wide x 415.5 deep
- Hinges
- 1/4" x 1/8 Gasket Material
Interactive model
https://myhub.autodesk360.com/ue2bc5d44/g/shares/SH9285eQTcf875d3c53959473f32555af79b
