I wanted to use the LDO breakout board and pre-made cable with my Voron build, but didn't have enough room on the DIN rails to mount it, so I made this frame mounted board holder for it.
It's a combination of the LDO din mount bracket, along with a 2020 mount from the Wago mount that comes with the Voron STLs. And a small reinforcement from one of the side skirts. Anyway, it's a mashup of things to make something useful, at least for my build.
Use the standard 5mm bolts & 2020 inserts from the standard Voron build that the Wago mount uses.
