I needed Sturdy Handles for my heavy voron2.4 350 so i could move it and turn it on its side/back to facilitate maintenance but as the enclosure limits where you can hold it and also due to the enclosure creating a step over the aluminium extrusion (3mm plexi and 1mm foam tape) normal handles wouldn't work so i designed this handle to fit the top framing, i can now carry the whole thing to another room if needed....
parts used:
2x M5x15mm BHSC
2x M5 Tnuts
Printed with standard voron specs
