Adapted from the original power_inlet_IECGS_ part to accommodate a Schaffner FN9280 Ultra Compact Filtered IEC power module.
Left and Right versions provided.
Modded using Sketchup Pro 2022 (skp file provided).
Model is 100% watertight and easy to print.
The 4mm holes accept regular M3 heat inserts to secure the power module's flange (using M3x12 cone head machine screws).
