A belt tension helper - is a tool to do pre-tension of belts
A tool act as a helper to do initial belt tension. It is able to do individual belt tension or synced tension of belts
2 or 3 M3 8mm bolts to mount helper to X-carriage
2x15mm M5 bolts to fix belts when needed
2x40mm M5 bolts and M5 nuts to perform tension
While printing use higher infill for bottom or use cylidric modifies to add strength for pads where M5 bolts will do pressure See example here:
Steps to perform:
Step 1. Mount bottom part on X carriage and push thought belts. Keep in mind that loose belt backs square nut (use holes for regulate them)
Step 2. Put top part and pass thought belts. Screw tension bolts to have zero minimal gap between bottom and top plate
Step 3. Fix belts on top part but leave loosen on bottom
Step 4. Tension belt by turning the bolts synchronously (do it sequentially by one turn for each)
Step 5. When belt are in tesion fix them using service holes by allen hex key
Step 6. Loose all M5 and unmount top and bottom tool parts
(Optional). When need to do individual belt tension use combination of bolts fix or loosen. See example for case when need to do extra tension for top belt
