8
Microfit 2x3 Skirt Connector (ADXL)
Mod for a Microfit 2x3 connector to be mounted in the bestagons. Typically used for ADXL but can be used as a general connector for anything outside the printer.
Pro tip: I found that adding some hot-glue while installing it into the skirt makes it a bit more robust for unplugging and plugging in.
This is originally based off of this mod. It was modified to not require supports and have a bit tighter fit onto the connector.
- Default voron settings
- No supports needed
Size | Qty |
Microfit 0430200608 | 1 |
Microfit 0430250600 | 1 |
