Corner Cable Hide v. 2022.02.05
1 Screenshot
  • Like 19
  • Voron FTW! 3
  • Thanks 2
Top Corner Cable Hide/Cover (LED Wires)
Designed to hide cables that are running around the top corners of 2.4 extrusions behind the z idlers.
They are large enough to fit 3 pin microfit connectors.
There maybe some small loss in z. Don't forget to check your clearances after installing.
Pro tip: It may take some fiddling to get the wires to fit. You will know they are in place when it sits flush to the extrusions without wobbling. Also disable 'Thin Walls/Detect Thin walls' so the mounting ears print cleanly.
  • Default voron settings
  • No supports needed
Size Qty
M3x8 8
M3 T-Nut 8
Top Corner Cable Hides
