Neopixel Mount
These are neopixel mounts that slide into the V0.1's top extrusions (20 leds in total)
- Neopixel/WS2812B led strip (60 leds/m) only 34cm, 20 leds are needed
- Cables
Instructions
- Print 4 of the "Neopixel_Mount" (2 for each side)
- Solder only the 5V and GND wires on the led strips
- Slide them into the mounts
- Solder the signal wire based on the diagram below (There is a hole in the mount to allow the wire to go from the one strip to the other)
- Remove the 2 screws holding each extrusion into place
- Remove the 3 screws that attach the panels onto each extrusion
- Slide the mounts onto each extrusion and screw the extrusions in place
